5 Benefits of Using CNC Machining Technology
CNC machining has become a staple in the manufacturing industry. An ever-growing number of machine shops are adopting this form of machining in their operations.
Although many machinists have become accustomed to this form of machining, not all of them are aware of the logic behind it.
Here are the main benefits of using CNC machining over other forms of machining:
More Automated Than Conventional
As the name suggests – CNC stands for Computer Numerical Control – this form of machining relies heavily on computer control. This translates in a higher level of automation, which is the optimal solution for high precision work.
Varied Types of CNC Machining
Modern CNC machines are suitable for all types of cutting methods. CNC turning processes make it possible to create complex external and internal geometries, including generating all kinds of threads, while CNC milling is better for making holes, slots, and repeated motions to create intricate 3D shapes
Covers All Your Needs
CNC offers a pretty wide variety of tools, helping machine shops to create and replicate any type of geometry and engraving.
Improved Safety
While human operators are still needed to run the operations, they are no longer required to have their hands on the machine. This creates a safer work environment for all, reducing the incidence of workplace accidents.
Easy to Scale
CNC machining process is extremely easy to scale up. Machinists can just upload the same program used for the initial prototype on multiple machines to scale up the productions.
CNC machining is the way of the future, and its many benefits make it an obvious choice for manufacturers. As technology advances, manufacturing processes can advance alongside, opening doors for exponential technological growth.
1 Comment
It’s nice that you mentioned how CNC machining could create a safer work environment for all, reducing the incidence of workplace accidents. My friend and I are currently building a customized bike, however, it seems we would need some custom parts for it. I’ll try to consult with a CNC lathe machine shop later and ask them to make those parts for us.
