CNC Machining History: Punch Tapes Explained
July 17, 2020 10:31 am
Ever wondered how punch tapes could deliver so much information to machines? In this video, G-Code Tutor Marc Cronin explains to us how they work.
Punch tapes used to be the only way to store programming information back in the days. When “fed” to the machines, these strings of paper would deliver the information necessary to operate the program. The name “punch tape” comes from the holes punched on the tape that will be used to convert programming information into binary data. Punch tapes typically look like strings of paper with multiple lines of holes. Each line will feature either 5 or 8 holes. Each of these holes represents a bit and each line represents a byte. Once fed, the machine will use a light system to convert the holes pattern into information.
There are two standards of tapes engineers used to work with: EIA, also known as BCD, and the ASCII, which is known as ISO. Although identical in the looks, the two tape standards there’s one main characteristic that differentiates them: EIA system tapes will feature an odd number of holes on each line while ASCII system tapes will feature an even number of holes on each line. The reason this is done this way is to help the tape reader to identify an error and alert the operator.
Although machinists nowadays don’t have to deal with punch tapes, knowing how they work can help understand the difference between high-level programming and low-level programming. G-Code is considered high-level programming language because it converts into 0s and 1s that the machine’s CPU can read.
Have you ever worked with punch tapes or seen them in your machine shop? Share your experience in the comments!
To learn more about G-code editing or improve your programming skills visit Gcodetutor.com.
Make sure you LIKE and SUBSCRIBE to our YouTube Channel for more metalworking videos!
Recommended Videos
