CNC Setup Without Probes—Here’s How!
CNC setup doesn’t have to be a pain. No probes? No problem. Here’s a simple way to get your machine dialed in fast.
Welcome to The Process, a new series where Bradley Thomas from Marvel Machining shares his workflows that actually work in the shop. In this episode, he walks through his full CNC machine setup-from programming to work offsets and tool height setup-without using probes. Instead of relying on expensive touch-off systems, Bradley shows how a height stand and a solid process can get the job done just as accurately.
What to Expect in This Episode:
How he sets up CNC machines without probes
⚙️ A practical tool height setup method that works across multiple machines
⏳ Why this process saves time and avoids mistakes
The importance of work offsets and a reliable setup routine
Not every machinist has a high-end probing system, and that’s okay. This is a simple, repeatable way to set up your machine quickly and accurately.
If you’ve ever struggled with setup or just want a more efficient workflow, this one’s for you.
