Flex Machine Tools to Highlight Range of Advanced, Ergonomic Tapping, Drilling, Balancing and Material Handling Arms at IMTS 2024
Wapakoneta, OH — Flex Machine Tools, an American manufacturer and leading provider of machine tool solutions worldwide for metal fabrication operations and more, announced it will be demonstrating Tapping, Drilling, Balancing and Material Handling Arm products at the International Manufacturing Technology Show (IMTS) Booth #135204 in the Fabricating Pavilion (East Hall) at McCormick Place in Chicago, IL from September 9th -14th this year. IMTS 2024 marks the 40th year anniversary since Flex debuted its first tapping arm at IMTS in 1984.
Highlights this year will include the flexible FlexArm REM-24D Electronic Tapping Arm with a Multi-Position Head that allows quick and easy switches between vertical and horizontal tapping. Renowned for its ability to produce accurate tapped holes while minimizing the risk of tap breakage, the REM-24D Tapping Arm has a maximum reach of up to 70″ (1,778 mm) and is designed for taps up to 7/8″ (22 mm).
The FlexArm Mag Drill Arm will also be demonstrated, showcasing how magnetic drilling can be simplified, while reducing operator fatigue and increasing safety and efficiency. The ergonomic Mag Drill Arm offsets the drill’s weight by effectively reducing up to 75 lbs. (34 kg) of strain on an operator’s body. The Arm provides a working range of up to 100″ (2,540 mm) of horizontal reach and 52″ (1,320 mm) of vertical stroke, resulting in precision and versatility across a broad range of drilling operations.
For eliminating fatigue and repetitive motion injuries when grinding, Flex will demonstrate its B-33-RG Balance Arm for handheld grinders, designed to fit the specific grinder make/ model. The Balance Arm offers full range of motion similar to natural movements, and also extends the life of the grinding tool and abrasive product. The B-33-RG has a counterbalance capacity of 1-25 lbs., a reach range of 1″ – 72″ and 90 PSI air pressure.
Offering users twice the lift with half of the effort, Flex will also demonstrate its FlexArm Part Manipulator, an innovative material handling solution designed to optimize productivity and enhance safety. The FlexArm Part Manipulator can position parts, unload tools and hold workpieces. The tool is engineered to function in cramped workspaces where simple overhead cranes are not possible.
Visit Flex Machine Tools to learn more.
