How to Program a Needle Valve with Mazatrol [CONVERSATIONAL PROGRAMMING TUTORIAL] – Part 2
February 4, 2022 11:33 am
Part 2/2. How to do some Mazatrol programming on a lathe. In this video you’ll see the program from Part 1 programmed live on the machine.
The programming for this needle valve will require some threading and chamfering on the piece which will be accomplished through conversational programming on the Mazak lathe.
This needle valve is part of a project from Derrick Hogan’s (North Georgia Technical College) Lathe Operations II class. The class develops the components for an entire bottle jack, one of which is a needle valve that opens to allow fluid back into the cylinder.
Watch part one here.
This video was brought to you in collaboration with instructor Derrick Hogan of North Georgia Technical College. Learn more about North Georgia Technical College and their machining related programs here.
This video is part of our video series: ” LEARNING FROM THE PROS”! We are collaborating with educators from technical schools around the country to provide you with tips and tricks, educational videos, and machining technology insights that will help you become a better machinist and learn something new about our beloved metalworking trade.
Recommended Videos
