Hwacheon Hi-TECH 750A YMC Powerful Heavy Duty Turning Center
August 21, 2020 1:22 pm
Lincolnshire, IL –  The newly introduced Hi-TECH 750A YMC is quickly gaining popularity for its ability to machine high precision, heavy duty parts. Due to the Hi-TECH 750A YMC’s extensive range of specifications, industries all across the board from Heavy Transport, Construction & Agriculture, to Oil & Energy – benefit greatly from its outstanding machining performance. This high-power Turning Center was designed to easily handle large parts, so whether you’re machining hefty Oil & Gas parts or sizeable Heavy Transport components, the Hi-TECH 750A YMC maintains precision and accuracy throughout your entire machining process.
New double door exterior design allowing for easy access
The high level of machining accuracy is in large part due to the “Super High-Torque Built-in Gear Driven Spindle” that reaches up to 1,800rpm. The gear driven spindle not only greatly reduces machining time, it also enhances productivity when combined with its Y-Axis and Live Tooling functions. While the Hi-TECH 750A YMC is equipped with an 18” chuck, the Hi-TECH 750 B series comes equipped with a 21” chuck. Both the A and B series can handle up to a 24” Chuck with maximum cutting lengths up to 4,250mm, and a maximum cutting diameter of 760mm.
300mm wide heavy-duty turret, Long Boring Bar, ø80 / L800mm, with high performance tailstock and steady rest options
There are many other additional user convenience enhancements to the Hi-TECH 750A YMC, one of them being its wide door window, allowing for better visibility when machining large materials. The highly rigid built-in tailstock, wide disc turret, and powerful milling function solidifies this lathe is a force to be reckoned with.
Double doors are pictured open, easy access for large parts
Hwacheon is the leading South Korean brand in the production of robust and durable machine tools.
For more information on the Hi-TECH 750A YMC or to request a Catalogue, please visit www.hwacheon.com or e-mail hmainfo@hwacheon.com.
Company information:
Hwacheon Machinery America, Inc.
555 Bond Street – Lincolnshire, IL 60069
Tel.: (847) 573-0100 Fax: (847) 573-9900
E-mail: hmainfo@hwacheon.com, Website: www.hwacheon.com
