The Ultimate Guide to Micrometers
January 10, 2019 10:00 am
Micrometers, often called “mics”, are likely to be the most utilized precision measuring instrument in any machine shop. As they typically measure in .0001” increments (or .01mm for metric models), micrometers provide extremely accurate measurements and machinists often prefer them to other devices such as calipers.
Anatomy
Image credit: megadepot.com
As you can see in the image above, a traditional micrometer is generally composed of several different parts. Here are some important things to consider when choosing a micrometer:
  • ANVIL: Together with the spindle, the anvil is the part that will be in constantly in contact with the part and therefore the most likely to chip. For this reason, good models usually feature a carbide-tipped anvil that will allow for longer tool life.
  • FRAME: Frames come in a number of different sizes and shapes. Some shapes are designed for specific uses. The hub micrometer in the image below, for example, is designed to get into really small areas. When choosing a micrometer, always consider the type of part you are going to measure.
  • LOCK NUT: A spindle lock is handy to keep track of a measurement and also to lock the spindle for small lot gaging. Some micrometers have a lock nut (as shown), whilst others may have a locking lever. We recommend choosing the lever type as it seems to require less attention over the years and it’s easier to operate
  • SLEEVE SCALES: While all micrometers feature the main index scale on the sleeve, which measures in increments of .025”, the most accurate models also have a Vernier scale for more accurate measurements. Vernier scales measure in .0001”.
  • RATCHET SPEEDER: Many mics have a sort of slipping clutch mechanism that prevents over-tightening and aids the user to apply a constant measuring force to the spindle, helping to ensure reliable measurements. It’s not a life-changing feature, but it’s something to consider, especially important in production situations, with different operators, but one QC spec.
Digital vs analog
Newer models, the digital micrometers, have a digital display that makes it easier for you to read measurements. In terms of digital vs. an analog micrometer, there is not much difference in accuracy. Digital mics, however, offer two significant advantages: resolution and quick scale conversion.
The displays on most digital electronic micrometers, in fact, resolve to 0.00005″ and can be quickly converted from imperial to metric and vice-versa.
Since there’s not much difference between the two models, we usually recommend going with the most convenient option, which is generally the analog one.
If you are considering buying a digital mic, this is our recommendation.
Types of micrometers
As already mentioned, mics come in different sizes and shapes according to their intended use. Here are the three main types of micrometers that you will encounter when working in a machine shop:
Outside micrometers
Starrett Outside Micrometer with One-Piece Spindle,
The most widely used type if micrometer. It’s used to measure the distance between two external points of either round materials if you are working on a lathe, or square materials if you are working on a milling machine.
Inside micrometers
Mitutoyo 139-006 Tubular Vernier Inside Micrometer
Designed to take inside measurements, such as the ID of bushings or bearings. The most common models of inside mics look like outside mics without a frame and anvil, but other types, more similar to calipers, are also available.  Unlike outside mics, the read on the sleeve increases as the sleeve expands.
Depth micrometers
Fowler 52-225-110-0, Vernier Depth Micrometer With 0-4″ Measuring Range
Depth micrometers allow for precise measurement of depth for features like holes, slots, recesses of keyways. The tool has a hardened ground and a lapped base attached to the micrometer head. Like inside mics, the measurement increases as the rod extends into the hole.
What type of micrometer should you buy?
If you are just approaching the trade and thinking about where you should start investing to build your personal toolbox, we definitely recommend starting with the best 0-1’outside mic you can afford, as it’s most likely the tool that you are going to use most. Later on, you might fill in with additional micrometers, like a 0-6” set, but you’ll likely use them less often so we recommend investing more in the first one and settle on cheaper models for the add-ons.
As already mentioned above, mics vary depending on the intended use so the best advice we can give is to identify the type mic that you will be using most (outside, inside or depth) and invest in that.
Best models
OUTSIDE MICS
Brown & Sharpe 599-1-50 Classicmaster Micrometer
ORDER NOW
Our favorite model.
  • Carbide anvil
  • .0001” accuracy
  • Locking Lever
  • Friction thimble
Mitutoyo 101-117 Outside Micrometer
ORDER NOW
  • Carbide anvil
  • .0001” accuracy
  • Locking Lever
  • Friction thimble
Starrett T444.1XRL-1 Outside Micrometer
ORDER NOW
A great quality mic, only third in our list due to the lock nut type.
  • Carbide anvil
  • .0001” accuracy
  • Lock Nut
  • Friction thimble
INSIDE MICS
Mitutoyo 139-201
Mitutoyo 139-201, 1.5″ – 12″ X .001″ Tublar Inside Micrometer
ORDER NOW
Tubular inside mic. It comes with interchangeable rods that allow you to measure ID up to 12”.
Fowler 52-275-005 Xtra-Range Inside Micrometer
Fowler 52-275-005-0, Iside Micrometer with 0.2-2.2″ Measuring Range
ORDER NOW
More similar to a caliper, the frame is specially designed to enable the micrometer to provide extremely accurate small internal measurements.
DEPTH MICS
Starrett 440, 445 Vernier Depth Gauges
Starrett Micrometer Depth Gage a Combination Ratchet and Speeder in Case
ORDER NOW
Depending on the model, you can measure up to 12” in depth. It comes with a ring-type knurled lock nut, ratchet, and speeder for stability and to apply uniform pressure and make quick adjustments for precise measurements.
Mitutoyo 129-127 Depth Micrometer
ORDER NOW
Includes interchangeable 0.157″ diameter measuring rods that can be adjusted in 1″ increments for flexibility up to 4”.
This post may contain affiliate links. Please read our disclosure for more info.
Recommended Content
16 Comments
  • LocoMarty says:
    In my years of experience, since 1977, carbide face mics are more prone to being chipped. And in a lifetime of use, non carbide faced mics are not likely to be worn out, if used correctly.
  • Tim says:
    I have used Starrett, Brown and Sharpe, Mitutoyo, and off brand Polish mikes throughout my machine shop career. You may not like the lock on the Starrett’s, but the feel of them is second to none. Browne and Sharpe have to smooth of a feel, and Mitytoyo are, in my opinion, a step below the Starrett. Surprisingly, the first set I owned, the off brand Polish, were very nice, but you can no longer find these as easily as you could in 1985.
  • juanchus says:
    very usefull artlce, tanks for this type or information. I espect to go more deep knowlege in it`s issue , see you latter
  • Bob says:
    I feel that you missed some , such as thread mics and tube wall thickness mics, which would be of interest to those who haven’t met them in their field.
  • Rohan says:
    Very informative article. May include some detail on use of micrometer (least count, error) and how to read.
    Regards
  • Mike says:
    Nice job on the micrometer article.
    Now I’d like to see an article on micrometer calibration done by the user. Thank you
  • Murph says:
    Not a big fan of Carbide anvil mics and still prefer my old hand me down Starrett 0-1 from my uncle Pete from the 50s. They just have a feel like nothing you can buy today.
  • exMachina161 says:
    The Best OD mics I’ve ever owned are Swiss Etalon micrometers. Unfortunately, they are being phased out in inch reading, but Swiss made B&S come in a close second.
    Swiss made Etalon micrometers are the best I’ve ever owned and used. B&S Swiss made come in second.
    The Etalon mic will last forever if taken care of. Really well made and super smooth. Very accurate.
  • Vmc750 says:
    Feel like you missed out on intramik style bore micrometers. These are great to have, although a bit expensive.
  • Bobsmith says:
    WHAT???? Lufkin never made the list??
  • MDSpencer says:
    Lufkin mics are or were the best.
  • toglhot says:
    I like the $5 Chinese mics, they work well and are very accurate, best of all they are cheap!
  • Keroseneian says:
    The British ‘Moore & Wright’ has a long history of manufacturing mics in Britain, may be it is not popular in North America.
    The more recent China mics are quite alright in terms of accuracy and smoothness. There are a number of mic manufacturers in China, inexpensive but good for general shop measurements: for example, a 0-25 mm mic with built-in digital counter (mechanical and hence don’t need batteries) cost less than ten dollar (yes less than US$ 10) !
  • Bob says:
    I have been using micrometers since the 1960’s. My first 0-1″ micrometer was a Lufkin. Purchased a set of Mitutoyo mic’s up to 6″, have never looked back and am still using them. They are like new even they were used very often over my 50+ years as a machinist and gunsmith. I have never chipped the carbide faces on any of my mics, have never seen one chipped.
  • Dave says:
    Very informative information in the mics, in reference to carbide anvils. You have to have them if you are measuring tungsten carbide products or else they would wear out very quickly. Steel Anvils would last less than a year.
