KYOCERA SGS Precision Tools Launches APEX Application Expert to Assist Machinists in Making Critical Decisions
February 18, 2025 1:06 pm
The right data, right when you need it!
KYOCERA SGS Precision Tools proudly announces the launch of APEX, the SGS Tool Application Expert. This web tool is your go-to source for optimizing machining performance. From accessing detailed application data to comparing tools and generating professional reports, APEX streamlines the process of maximizing productivity and precision.
What APEX Brings to Your Shop
  • Faster, Smarter Decision-Making – No more hunting through spreadsheets or catalogs. APEX provides instant access to application-specific data so you can move quickly and confidently.
  • Optimized Performance – Get dialed-in recommendations for speeds, feeds, and cutting parameters based on material, tool type, and operation.
  • Side-by-Side Comparisons – Compare multiple tools at once to evaluate material removal rates, cutting parameters, and efficiency.
  • Exportable Reports – Generate PDFs with your selected tool specs and machining data, making it easy to share or reference later.
  • Built for Machinists – Simple, intuitive, and designed to be a real tool—not just another calculator.
Get started today at www.kyocera-sgstool.com/apex
