New Coated Ceramic Inserts from Walter Deliver Superior Performance and High Process Reliability
September 29, 2021 7:49 am
Coated mixed ceramic grade WCH10C provide cost effective machining for finishing cuts on hard or soft materials.
Waukesha, WI — Walter has introduced a new line of coated ceramic indexable inserts, grade WCH10C. The new Walter grade is mixed ceramic Al2O3 + TiC, and provides cost effective machining, including hard machining. The high level of process reliability is due to the high chemical and thermal stability of the aluminum oxide base as well as the negative chamfer T-land), all promoting a strong cutting edge. They feature TiN PVD coating for improved wear detection and surface quality and are available with or without wiper geometry.
Walter Ceramic grade WCH10C
The new Walter WCH10C inserts deliver high repeat accuracy due to its sintering process and are tough and wear resistant due to the strong connection to their titanium carbide substrate. Optimum surface quality is promoted as well by their uniform grain distribution in the substrate, The new Walter coated mixed ceramic grade WCH10C inserts can be used effectively on materials ranging in hardness from 45 up to 60 HRC. The inserts can be a cost-effective alternative to CBN cutting tool materials.
Additionally, WCH10C ceramic grade can be used in case hardened materials where the insert encounters both hard and soft turning conditions simultaneously; an application where CBN usually does not succeed well.
Walter, a global leader in the metalworking industry for over 100 years, offers a wide range of precision tools for milling, turning, drilling and threading applications. The company helps customers in the aviation and aerospace industries, automotive, energy, and general industry improve process reliability and increase productivity. As an innovative partner capable of creating digital process solutions for optimal efficiency, Walter is pioneering Industry 4.0 throughout the machining industry. With Regional Headquarters in Waukesha, WI, Walter markets its competence brands Walter, Walter Titex, Walter Prototyp and Walter Multiply through a network of channel partners and field engineers across the USA, Canada, Mexico and Brazil. www.walter-tools.com/us
