New indexable insert from Walter for the M4002 high feed milling cutter optimizes performance and economy.
Walter universal system of indexable inserts reduces cost and lowers power requirements.
Waukesha, WI — Walter has introduced an SDMX indexable insert for its Walter M4002 high-feed milling cutter. This square positive, cost-effective universal insert lowers power requirements thanks to its highly positive geometries. The new indexable inserts are thick for maximum process reliability and provides four cutting edges per indexable insert with a curved cutting edge for maximum stability.
Walter M4002 face milling cutter with SDMX indexable insert.
There are two indexable insert sizes with facet—SDMX0904ZDR-E27 and SDMX1205ZDR-E27. The M4002 cutter provides a depth of cut of 1.5 or 2.0 mm and is available in diameters of 25-125 mm or 1-4 in. and is ideal for high-speed milling in steel and cast iron, stainless steel and materials with difficult cutting properties. And for demanding machining in mold and die making and general machining.
Walter, a global leader in the metalworking industry for over 100 years, offers a wide range of precision tools for milling, turning, drilling and threading applications. The company helps customers in the aviation and aerospace industries, automotive, energy, and general industry improve process reliability and increase productivity. As an innovative partner capable of creating digital process solutions for optimal efficiency, Walter is pioneering Industry 4.0 throughout the machining industry. With Regional Headquarters in Waukesha, WI, Walter markets its competence brands Walter, Walter Titex, Walter Prototyp and Walter Multiply through a network of channel partners and field engineers across the USA, Canada, Mexico and Brazil. www.walter-tools.com/us
