New PCD Face, Shoulder and Slot Drill Milling Cutters from Walter Reduce Cutting Forces and Vibration.
March 21, 2022 2:44 pm
The MP060, MP160, MP260 boost machining of aluminum, and other non-ferrous metals, as well as composites, and fiber-reinforced plastics.
Waukesha, WI — Walter has introduced the MP060, MP160 and MP260 face, shoulder and slot drill milling cutters with brazed PCD cutting edges, a new suite of products for machining aluminum, Al-Si alloys, magnesium and magnesium alloys, as well as composites and plastics. These new milling cutters offer significant benefits, primarily with respect to their service life, surface quality and efficiency.
The MP060 face milling cutter with a great number of teeth (z) between 10 and 22, and with diameters from 40 mm, can be used for roughing and finishing large surfaces and flat shoulders. The MP160 (z = 3–4) and MP260 (z = 2–3) shoulder and slot milling cutters, with either cylindrical shank or ScrewFit adaption and diameters of 16–40 mm and 4–20 mm respectively, are suitable for smaller flat surfaces, for plunging (MP260) and full slotting, as well as, in the case of the MP160, ramping, drilling and re-drilling work. All three milling cutters are equipped with internal coolant supply and can be used with emulsions and minimum quantity lubrication.
Walter MP060, MP160 and MP260 PCD milling cutters
The service life of these new milling cutters, which is significantly longer than that of solid carbide tools, is primarily the result of the wear-resistant WDN20 Walter grade, as well as reduced cutting forces and low-vibration microgeometry. Their precise machining, combined with the internal coolant supply, enables users to produce high-quality surface finishes. In addition, relatively low cutting material costs, fewer tool changes due to the longer service life, and the fact that the milling cutters can be reconditioned (diameters of 6 mm or more) also increase the tools’ service life. These new Walter milling cutters are particularly well suited for the automotive, electronics and general metalworking industries.
Walter, a global leader in the metalworking industry for over 100 years, offers a wide range of precision tools for milling, turning, drilling and threading applications. The company helps customers in the aviation and aerospace industries, automotive, energy, and general metalworking industry improve process reliability and increase productivity. As an innovative partner capable of creating digital process solutions for optimal efficiency, Walter is pioneering Industry 4.0 throughout the machining industry. With Regional Headquarters in Waukesha, WI, Walter markets its competence brands Walter, Walter Titex, Walter Prototyp and Walter Multiply through a network of channel partners and field engineers across the USA, Canada, Mexico and Brazil. www.walter-tools.com/us
