Solutions to Aluminum Milling Problems
“Aluminum milling is easy.” Think again. Can this be deemed an industry myth? Here are solutions to troubleshoot aluminum milling problems and issues that go along with aluminum turning, drilling and boring.
Built Up Edge
Consider the Built Up Edge to be one of the biggest problems in aluminum cutting. Uncover the two main reasons for this effect here.
Simple but effective solutions to minimize the built up edge:
- Higher cutting speed
- PVD coatings
- Polished edges
- Abundant coolant
- Non-honed tool edges
Chip Control
Long chips are common in aluminum cutting and are problematic. They harm the surface finishing and pose safety risks for the operator.
The following actions need to be taken to upgrade the chips condition:
- Changing cutting parameters- increase depth and shorting the forward
- Use of positive or ultra-positive tools
It is always safe to use the highest parameters possible in aluminum operations. This is not the case with other metal cutting applications.
Want to avoid aluminum milling problems and achieve great results with your aluminum applications? Then read the full article here.
1 Comment
As a machinist and then drilling specialist, I cannot tell you how many times I was bitten by machining problems with aluminum because of my.easy peasy attitude!
