Tap Performance Troubleshooting – Part 3: Excessive Wear
June 5, 2019 2:20 pm
SPONSORED CONTENT
A series from Walter Tools USA
The following is one part in a series of articles regarding performance problems associated with the tapping process.  The solutions focus on specific actions to counter specific issues.
This article addresses remedies for the issue of Excessive Wear.  We are offering suggestions and changes that can be made to counter the effects of premature wear.  For further information regarding chip control, please see other articles in this series such as insufficient tool life, chip control,  fractures, chip welding or tool breakage.
Action to correct excessive wear will depend on the type of wear that we see, and in which part of the tap the wear is occurring.  It’s important to examine the used tool to determine which type of wear the tool is experiencing.
Tap wear
Anatomy of a spiral point tap and a spiral flute tap
Let’s take a look at the different types of wear that we expect to see.
Excessive Wear on the First Tooth
Excessive wear on the first tooth
Excessive wear on the first tooth means that the tap hole has been hardened by the drilling process
Cause
Edge zone hardening caused by the core hole drill
Solution
Optimize the core hole drilling process by incorporating as many of the following changes as possible.
  • Improve the coolant supply by adding internal coolant to the drilling process if not using already. If internal coolant supply is already being applied, increasing the coolant supply pressure or even the concentration level of water-soluble coolant to increase lubricity.
  • Reduce the cutting speed of the drill operation
  • Reduce the advance per revolution (feed rate) of the drill
  • Replace worn drills sooner
Wear in the Chamfer Area
Wear in the chamfer area
Wear in the chamfer area means that there is friction between the tool and the workpiece
Cause
Friction between tool and work piece. This could be considered typical wear and is not necessarily indicative of a problem.
Solution
  • Use a tool that is more wear resistant such as solid carbide taps
  • Increase the flank relief angle. This could have a negative side effect and may result in axial miscut or built up edge.  The trade-off has to be evaluated to determine if  the net effect to the operation is beneficial.
  • Improve the coolant supply by adding internal coolant if not using already. If internal coolant supply is already being applied, increasing the coolant supply pressure or even the concentration level of water-soluble coolant to increase lubricity.
  • Reduce the cutting speed of the tapping process
  • When machining materials with spring back effect, make sure that the tool cuts free (large rake and helix angle, sharp cutting edges)
Wear in the Guidance Part
Wear in the Guidance part
Wear in the Guidance part means that there is friction between the part and the relief angle
Cause
Friction between the relief face and the component. Wear on the first full tooth of the guidance section of the tap leads to wear on the subsequent teeth in the guidance area. The thread then becomes tighter and tighter. This could be considered typical wear and is not necessarily indicative of a problem.
Solution
  • Use a more wear resistant substrate such as solid carbide taps
  • When having excessive wear on the outer diameter of the guidance part, a tap with a relief angle on the outer diameter should be chosen. Workpiece materials with spring back effect and abrasive materials require such a relief angle.
Crater Wear
Crater Wear
High cutting speeds is one of the causes of Crater Wear
Cause
Crater wear can be caused by a number of different scenarios.  To some extent, this can be considered typical wear, but the following scenarios can be the root cause that needs to be addressed.
  • high cutting speeds
  • tough materials
  • Tools are being run too long
  • tool substrates that are prone to wear
  • insufficient coolant conditions
Solution
  • Use tool that is more wear resistant such as solid carbide taps
Rounding of the Cutting Edge
Rounding of the cutting edge
Rounding of the cutting edge is caused by a combination of crater wear and wear in the relief area.
Cause
Combination of crater wear and wear in the relief area. This could be considered typical wear and is not necessarily indicative of a problem.
Solution
Didn’t find a solution to your issue? For a remedy that does not involve such direct customization, try a tap designed around a universal application range that can be appropriate for a wide range of materials like Walter Tools’ TC117 / TC217 Advance. These universal taps provide excellent process reliability, outstanding chip control, and high productivity in a wide range of materials. Check out this video that demonstrates the performance of these unique tools.
Check out this Threading Handbook to learn more thread production technology, trends, and innovation, or to find the right tool for your needs.
