Dial Indicators: Most Recommended Models of 2020
June 1, 2020 10:40 am
Best for repetitive and comparative measurements, the dial indicator is an inspection and measurement device often used to check the variation of a machined part’s tolerance by measuring linear movement. To maintain straightness, the dial is mounted to a fixture which enables vertical movement to ensure that the contact point always lands in the same place, relative to the fixture. Therefore, the dial indicator must be oriented vertically to whatever is being measured.
Despite the common name, dial indicators are anatomically very different from dial test indicators. In this article, we’ll dig deeper into dial indicators, explore their functions, features, and take a look at the most recommended models by our community.
To learn more about the differentiation between the two tools, check out Choosing the Right Dial Indicator. If you’re interested in learning more about dial test indicators, read about the Top 5 Dial Test Indicators of 2020.
Tool Anatomy
Dial indicators have plunger type contacts that are a spring-loaded part. The plunger is raised or lowered by the surface below and the dial indicator reads that movement. From the zero-reference point there are two basic outcomes that apply. When the plunger moves out of the case and the needle moves counterclockwise, this is a negative reading. Alternatively, when the plunger moves inward, toward the case, the needle movers in a clockwise direction which is a positive reading.
Image Credit: https://www.alignmentknowledge.com/
The user must simply note whether the needle lies within the tolerance bands. This is what makes the tool so user friendly as no interpretation is needed.
Though these tools are heavy in weight, do not underestimate how fragile they are. Indicators are very susceptible to damage, so avoid excessive force whenever possible.
Common Uses
The dial indicator is a primary measuring tool in precision engine building. In this case, they are commonly used to measure deck clearances and crankshaft thrust and straightness.
You will also see this tool used frequently in quality checks to confirm consistency and accuracy in the production process.
Other common uses of the tool include measuring:
  • Value lift
  • Journal concentricity
  • Flywheel or a brake rotor run out
  • Gear backlash
  • Crankshaft end play
Best Practices
Make these best practices a habit so your tool performs successful measurements and lasts a long time.
  • Ensure that your dial indicator is nuzzled up close to its mount to minimize the risk of rod deflection.
  • Keep the reference surface, the test base, and the indicator spindle clean.
  • Test the readings multiple times throughout the day to ensure accuracy. This can be done by comparing the reading to a master part.
Keep your indicator safe – they are a highly delicate tool! If you drop or damage your dial indicator, it is important that you test it thoroughly before allowing it back into production.
Recommended Models
To help you identify which dial indicator is best for you, we reached out to the Practical Machinist community via social media and gathered a list of their favorite models. Here are the top 5 dial indicators models they recommended.
Mahr Federal B7I AGD 1 Dial Indicator
Order Now
Used to measure dimensional deviations with graduations of 0.0005” and accuracy up to +/- 0.0005”, this dial indicator features a light green face to provide comfort on the eyes. This tool features jeweled bearings that resist friction, hobbed gears to promote more sensitive responses, and weighs about 3 pounds.
Mitutoyo”2416S” Dial Indicator
Mitutoyo “2416S” Dial Indicator
Order Now
The Mitutoyo dial indicator comes with the choice of a flat or lug back, so it is compatible with a variety of mounting options. You can also choose between a black or white face depending on your preference.
Brown & Sharpe 14.82023 Dial Indicator
TESA Brown & Sharpe
Order Now
The 2-1/4” diameter rotating dial indicator makes this too great for both vertical and horizontal measurements. The dial indicator reads to 0.001” and features a bright orange hand to make readings as easy as possible.
Fowler FOW72-520-110 Dial Indicator
Order Now
The Fowler dial indicator features a lug back, so make sure you have a compatible mount (or purchase one accordingly). The spindle and contact points are stainless steel to support longevity. Nothing but good words surround this tool.
TECLOCK 4409-1001 Teclock Dial Indicator
4409-1001 Teclock Dial Indicator, 0-1″
Order Now
Despite the low-price tag on this tool, the Practical Machinist community confirmed that reliability is definitely not sacrificed. This dial indicator has even been compared to the Mitutoyo model due to its accuracy and sturdiness.
This post may contain affiliate links. Please read our disclosure for more info.
Recommended Content
5 Comments
  • Gage Guy says:
    Re- Recommended Models:
    Mahr/ Federal Over priced and repair parts are very expensive. Starrett makes an AGD 1 better for less.
    Mitutoyo 1″ Travel Indicator bottom bushings fall apart and the plastic Crystal Bezel Assy. is fragile and pricey
    Brown & Sharpe have German parts also most are not available
    Fowler products are for the most part Chinese and no replacement parts available
    Teclock is a nice throw away gage, no parts available. Made in Japan
  • Bob says:
    Hello,
    The Federal dial indicator does not weigh three pounds. That must be a misprint. The Mahr/Federal is a very good indicator, as are most of those featured.
  • Norton says:
    I use the cheapest indicators I can find in our job shop. A thousandth is a thousandth and if i send it across the room at the speed of light, I WILL NOT BE CRYING ABOUT IT..
  • Indicare says:
    Been repairing indicators for over 40 years. Starrett AGD dial indicators are still the best and most durable models. So many manufacturers have gone to plastic works on their indicators. (even Starrett)
    Mahr/Federal parts are so expensive you can’t repair reasonably. Mitutoyo has the best parts drawings and pricing.
    Teclock and Fowler styles are “throw away” models with little or no parts available.
    In my opinion, I would rather work on the Mahr/Federals or Starretts, (so easy to adjust rack & gear clearances to obtain NIST tolerances) But hate to quote the Mahr/Federal repair to my customer because of parts cost.
